Results 1 to 10 of 13
    Jan 2002
    Angry
    I have set oracle9i as mts server,all MTS processes alse are running ,but when i use sqlplus to connect to oracle mts ,it is return error message ora-12520 .But i connect to it when force the dedicated mode in tnsnames.ora,it is ok .
    Any one can help me?
    [Edited by hepinge on 03-19-2002 at 07:18 AM]
    Feb 2000
    Use the 'lsnrctl services' command for the listener to see what has dispatchers/servers etc have been started and the status of each....
    Cheers
    Moff.
    Saskatoon, SK, Canada
    That was because your dispatchers have not been registered or started.
    Jan 2002
    hi moff:
    Originally posted by moff
    Cheers
    Moff.
    This is the part result of 'lsnrctl services'
    "D002"
    DISPATCHER
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=bbsdb)(PORT=33747))(PRESENTAT
    ION=oracle.aurora.server.SGiopServer)(SESSION=RAW))
    "D001" :
    DISPATCHER
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=bbsdb)(PORT=33746))(PRESENTAT
    ION=oracle.aurora.server.GiopServer)(SESSION=RAW))
    so how can i do?
    Jan 2002
    HI sambavan:
    Please see my reply above,please tell me how can i do??
    I think the dispatchers has been registered and started.Is that right?
    Oct 2001
    Probably you have started your listener after you started the database, then your dispatchers haven't been initialized.
    You have to restart your database to initialize the dispatchers.
    Angel
    Jan 2002
    hi aarroyob:
    Angel
    I first start listener and start oracle instance . Can you tell me is there something special on init.ora ¡¢listener.ora and client's tnsnames.ora in MTS mode?
    Oct 2001
    What do you have in the init.ora, tnsnames.ora and listener.ora?
    Jan 2002
    hi aarroyob:
    parameters about mts in init.ora :
    dispatchers="(PROTOCOL=TCP)(SER=MODOSE)"
    dispatchers="(PROTOCOL=TCP)(PRE=oracle.aurora.server.GiopServer)"
    dispatchers="(PROTOCOL=TCP)(PRE=oracle.aurora.server.SGiopServer)"
    parameters in listener.ora :
    LISTENER =
    (DESCRIPTION_LIST =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC))
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST =bbsdb)(PORT = 1521))
    parameters in tnsnames.ora :
    CLUBDB =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS = (PROTOCOL = TCP)(HOST = bbsdb)(PORT = 1521))
    (CONNECT_DATA =
    (SERVICE_NAME = clubdb)
    (server=shared)
    Oct 2001
    In my init.ora I have this:
    large_pool_size = 50M
    mts_servers = 10
    mts_max_servers=20
    mts_dispatchers="(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1522))(dispatchers=1)"
    mts_dispatchers="(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1523))(dispatchers=1)"
    mts_dispatchers="(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1524))(dispatchers=1)"
    mts_dispatchers="(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1525))(dispatchers=1)"
    mts_dispatchers="(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1526))(dispatchers=1)"
    mts_max_dispatchers=20
    local_listener="(ADDRESS_LIST=(ADDRESS=(PROTOCOL=tcp)(HOST=host_name)(PORT=1521)))"
    mts_service=instance_name
    The other file i think are correct if your host_name=bbsdb. Is it?
    Cheers
    Angel
