Underscore problem
Results 1 to 10 of 10
Thread: Underscore problem
    I have inserted some data starting with _(underscore). I would like to query the column to get the only the underscore rows. Can any one help me?
    rammi
    select column_name from your_table
    where column_name like '_%';
    Hope it helps
    Cheers
    Fabien
    Thanks for the reply. But that doesnt work. It fetches all the rows. Any other solutions?
    rammi
    Jun 2001
    Helsinki. Finland
    Originally posted by ramya_ram
    This is a solution, not a suggestion :-)
    where substr(column_name,1,1) = '_';
    where column_name like '\ _\%' ESCAPE '\' ;
    The substr option is working fine. But I wanted to know the other query which I tried and getting no rows. I have given the results below for your reference.
    1 select type from type_designation_tab
    2* where substr(type,1,1)='_'
    TYPE
    _IBMNETFINITY4500R
    _NETFINITY5600
    _DELLPWREDG1300
    _NETVISTACELERON
    _IBM-PIII
    SQL> select type from type_designation_tab
    2 where type like '\_\%' ESCAPE '\';
    no rows selected
    SQL>
    rammi
    Mar 2002
    Ramya, try this:
    where type LIKE '%^_%' ESCAPE '^';
    This shd work.
    Jul 2000
    india
    Why u require a % before the _(underscore) when the requirement is the rows starting from _(underscore)..
    i think the query should be
    where type LIKE '^_%' ESCAPE '^';
    Hope i am right..
    thanks pras
    Thanks a lot. It is working fine.
    rammi
    Mar 2002
    You are right Pras. I was just putting forth the syntax, didn't observe the specific.
