    Oct 2001
    Buffalo, NY
    Exclamation
    Here's my setup:
    One UNIX server with multiple DBs
    Two listeners - one that services all DBs (including the traxtest DB) via TCP
    one that services just the traxtest DB via IPC
    listener.ora syntax:
    listener_d1 =
    (ADDRESS_LIST =
    (ADDRESS =
    (PROTOCOL = TCP)
    (Host = pisa)
    (Port = 1521)
    (QUEUESIZE=100)))
    SID_LIST_listener_d1 =
    (SID_LIST =
    (SID_DESC =
    (GLOBAL_DBNAME = traxtest.world)
    (SID_NAME = traxtest)
    (ORACLE_HOME = ...)
    listener_traxtest =
    (ADDRESS_LIST =
    (ADDRESS=(PROTOCOL=ipc)
    (KEY=PNPKEY)))
    SID_LIST_listener_traxtest =
    (SID_DESC =
    (ORACLE_HOME = ...)
    One tnsnames.ora file:
    traxtest.world =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (ADDRESS =
    (COMMUNITY = tcp.world)
    (PROTOCOL = TCP)
    (Host = ...)
    (Port = 1521))
    (ADDRESS =
    (PROTOCOL = IPC)
    (KEY = PNPKEY)))
    (CONNECT_DATA = (SID = traxtest)))
    Both listeners are up. Then on another DB on the same server I create a private DB link to traxtest:
    create database link traxtest
    connect to tntdev_to_traxtest_link
    identified by ...
    using '(DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=PNPKEY))(SID_NAME=traxtest))';
    However, when I SELECT using the link, I get the following:
    SQL> select * from global_names@traxtest;
    ORA-12504: TNS:listener was not given the SID in CONNECT_DATA
    I have tried several differnet combinations of DB link descriptions, but to no avail. Does anyone have a clue as to the problem here? I've never set up an IPC connection before.
    Tim Hussar
    Oct 2001
    Buffalo, NY
    Unhappy
    Could anyone offer a suggestion on the below?
    Tim Hussar
    I'm not sure that this will help but maybe.
    When I create a link here we use the following.
    SQL> create public database link link_name
    connect to the_id identified by psswrd
    using 'DXXX.oracledb.blah.com';
    MH
