Results 1 to 8 of 8
Thread: import tab delimited file
    Mar 2000
    woodbridge,nj,USA
    DBA's
    I have the following problem:
    I need to import a multi-record type tab delimited file
    into a set of Oracle tables based on each record type.
    If anyone has done something similar or has any idea how
    do import this type of file I will appreciate the help.
    The tab delimited file looks like :
    101-1joesmith
    101-2New Jersey
    102-1PaulJones
    102-2New York
    101 is the employee number -1 and -2 are the record type indicators.
    Record type 1 records are loaded into table
    emp_names
    (emp_num varchar(10),
    fname varchar(20),
    lname varchar(20))
    Record type 2 records are loaded into table
    emp_state
    state varchar(20),
    Umesh
    greenwich.ct.us
    Portsmouth, NH, USA
    Talking columns seperated by ...
    'X09'
    (or is it X'09'? I forget)
    that works for me when I have tab delimited
    If you cannot get the tab-delimited to load, sometimes I open the file (in word or textpad or whatever) and "replace" all the tabs with tildes (~) or something. That is easy to do as well.
    - Magnus
    greenwich.ct.us
    Re: columns seperated by ...
    Originally posted by jgmagnus
    X'09'
    is correct
    Portsmouth, NH, USA
    Talking *phew*!
    thanks for the confirmation.
    good thing I caught my own mistake!
    - Magnus
    greenwich.ct.us
    Re: *phew*!
    If not, you know jmodic would be all over it like a hobo on a ham sandwich.
    Mar 2000
    woodbridge,nj,USA
    solution
    Thanks DBA's
    SQLLDR worked fine using the following syntax :
    LOAD DATA
    INFILE 'orderh.txt'
    REPLACE
    INTO TABLE order_rectype1
    WHEN rec_type = '1'
    (field1 terminated by x'09',
    INTO TABLE order_rectype2
    WHEN rec_type = '2'
    etc
