    New York , New York
    I am getting the error expression of wrong type when i try to compile the following procedure.
    SQL> declare
    2
    3 cursor c1 is select phone_type_id from lkp_phone_type;
    4
    5 type phone_type_id_list is table of Number index by binary_integer;
    6 p_phone_type_id phone_type_id_list;
    7
    8 begin
    9 for i in c1 loop
    10 p_phone_type_id(i) := i.phone_type_id;
    11 end loop;
    12
    13
    14 end;
    15 /
    ERROR at line 10:
    ORA-06550: line 10, column 19:
    PLS-00382: expression is of wrong type
    ORA-06550: line 10, column 3:
    PL/SQL: Statement ignored
    Please note that the phone_type_id column in the table lkp_phone_type is a NUMBER datatype field.
    whats wrong here.
    when i change the for loop to
    for i in 1..100 loop
    p_phone_type_id(i) := i;
    end loop;
    it works , although it does not solve my problem of what i want to do but whats happenning, I have no clue.
    Please Please Suggest. Its urgent
    Ronnie
    [Edited by ronnie on 11-20-2001 at 04:23 PM]
    Saskatoon, SK, Canada
    That is because the when you insert the data into the PLSQL table, there has to be an order of sequence..
      v_count := 0;               -- Remember to decaler v_count NUMBER (20) := 0;
      FOR i IN c1 LOOP
         v_count := v_count + 1;
         p_phone_type_id(v_count) := i.phone_type_id;
      END LOOP;
