Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Jul 2000
    okay, so you are talking @ actual columns and not the records in the table. I thought your example of selecting from USER_TAB_COLUMNS was just an example.
    So, if you spool to a file :
    awk '{ printf("%s,",$1) }END{ printf("\n")}' your_spool_file
    should do the job.
    svk
  2. #12
    thanks SVK, it works.
    but I still need your help.
    The result:
    cust_id,cust_name,cust_descp,updateuser,
    How I eliminate the last ",".
    thanks, again
  3. #13
    Jul 2000
    Once you execute the awk, you can used sed to eliminate the last ','.
    Or, you can use a simple logic in awk to check for the record number (NR) and don't print the ',' for the first record and print a ',' before the actual field for all other records. Simple.
    svk
  4. #14
    svk,
    I am not good at either one. I try to use MAN to figure out how but no answer. Could you please give me the syntax.
    thanks.
  5. #15
    Aug 2001
    Hi, I am not quite sure what you want, but under the assumption that you are only interested in the second field for every 5 line, here's a script that might do just that. It could be shorter, but here it is:
    script:
    #!/bin/sh
    #!/bin/sh
    awk '{
    if($2 != "") {printf "%s," ,$2; }
    if(getline) {printf "%s," ,$2;}
    if(getline) {printf "%s\n" ,$2;}
    }' < punt
  6. #16
    Jul 2000
    Lets get this completed :
    Create a .sql file as follows :
    spool /tmp/x
    set pages 0
    set lines 200
    set feedback off
    set head off
    select table_name,column_name,data_type,column_id
    from user_tab_columns
    order by 1,4;
    spool off
    Executing this file script will create a spool file /tmp/x.lst that is in the format that you have been mentioning since begining.
    Now, create this awk script : (lets call it /tmp/x.awk)
    BEGIN {
    prev_table="."
    curr_table=$1
    if ( curr_table!=prev_table )
    prev_table=curr_table
    printf("\nTable %s : %s",$1,$2)
    else
    printf(",%s",$2)
    Execute this awk script as follows :
    awk -f /tmp/x.awk /tmp/x.lst
    The output will be as follows :
    Table ABC : COL1,COL2,COL3
    Table DEF$_PROPAGATOR : USERID,USERNAME,CREATED
    You can redirect output of the above awk command to a file.
    If you do not want the "Table .... : " part in the output, edit the awk script as required.
    Does it solve the issue ?
    [Edited by svk on 08-28-2001 at 06:38 PM]
    svk
  7. #17
    Aug 2001
    So you want table_name,column_name,column_name,...
    use a cursor
    from dba_tab_columns (OR user_tab_columns)
    and loop for each table.
    use dbms.output to create the right output.
    Hope this helps
    Performance... Push the envelope!
  8. #18
    Talking
    Hello SVK
    could you plaese explain your code i am feeling it a bit diffcult to understand it.
    hrishy
  9. #19
    svk,
    thanks, it works perfectly.
    In fact, last night I use your previous suggestion
    at end I use sed to remove the pending ",".
    awk '{ printf("%s,",$1) }END{ printf("\n")}' your_spool_file | sed "s/\,$//g"
    both works !!! this is not the first time you help me out, thanks.
    jm
