How to restore Locally Managed Temporary Tablespace
Thread: How to restore Locally Managed Temporary Tablespace
    A data file for Locally Managed Temporary Tablespace was accidentally dropped on the OS level.
    I tried to restore, but got the following errors. How do you solve it?
    SQL> select tablespace_name, file_name, bytes/1048576 "MB" from dba_temp_files;
    ORA-01157: cannot identify/lock data file 201 - see DBWR trace file
    ORA-01110: data file 201: '/u03/oradata/ocom/big_temp01.dbf'
    SQL> ALTER TABLESPACE BIG_TEMP ADD TEMPFILE '/u03/oradata/ocom/big_temp01.dbf' SIZE 1073741824;
    ORA-01537: cannot add data file '/u03/oradata/ocom/big_temp01.dbf' - file already part of database
    SQL> alter database create datafile '/u03/oradata/ocom/big_temp01.dbf' as '/u03/oradata/ocom/big_temp01.dbf';
    ORA-01516: nonexistent log file, datafile or tempfile '/u03/oradata/ocom/big_temp01.dbf'
    Saskatoon, SK, Canada
    Since it was a temp table, you can just drop it and recreate one, without any worry of loosing information.
    Jun 2001
    Helsinki. Finland
    Do you know how to drop and recreate it?
    Talking
    since its a temproray tablespace you are safe to drop and recreate it.
    drop tablespace
    ALTER DATABASE BIG_TEMP '/u03/oradata/ocom/big_temp01.dbf' DROP;
    here the control file would be written to saying that your tempfile is dropped
    recreate the tablespace
    CREATE TEMPORARY TABLESPACE BIG_TEMP
    SIZE 20M REUSE
    EXTENT MANAGEMENT LOCAL UNIFORM SIZE 16M;
    hrishy
    Jun 2001
    this just drops the datafile virtually
    but physically it still xists on ur machine
    u would have to delete the file manually...
    it wont create any kinda problem..but it does eat up the space alloted to it...
