set verify off
set feedback off
set echo off long 5000
set pagesize 0 head off lines 1000
set termout on trimspool on
set serveroutput on size 1000000
Prompt
Prompt This script generates another script that will include all the CREATE
Prompt TABLE statements for those in the database (except for the SYS user).
Prompt (NB ensure screen buffer set to 1000 to avoid truncating long lines)
Prompt The dbms_output package must be available. Script runs for user accessible tables
Prompt only (change USER_/ALL_ to DBA_ if necessary)
Promp
clear columns
Accept Table_name Prompt 'Enter Table name to reverse engineer: '
Accept owner Prompt 'Enter owmer of Tables to reverse engineer: '
Accept add_owner Prompt 'Enter Y to prefix schema/user name to tablename, N if not: '
Accept storage Prompt 'Enter Y to add storage clause, N if not: '
rem
rem ***************************************************************************
rem ***** Set the following usesegs flag to Y to use the total number of bytes
rem ***** that the segment is currently using (instead of the table's
rem ***** originally-specified INITIAL_EXTENT value) as the value to use for
rem ***** the INITIAL_EXTENT in the script file that this script creates, so
rem ***** that the table will be recreated in a single extent. (The NEXT_EXTENT
rem ***** will be limited to no more than the INITIAL_EXTENT value.)
rem ***** (Set to 'N' to use the originally-specified INITIAL_EXTENT value).
rem
def usesegs='N'
Set termout off
Spool RE.tab
declare
cursor tab_cursor is select
upper(owner),
upper(table_name),
pct_free,
pct_used,
ini_trans,
max_trans,
tablespace_name,
initial_extent,
next_extent,
min_extents,
max_extents,
freelists,
freelist_groups,
pct_increase
from all_tables
where owner != 'SYS'
AND owner LIKE UPPER('&&owner')
AND table_name LIKE UPPER('&&Table_name')
order by owner, table_name;
cursor segments_cursor (s_own VARCHAR2, s_tab VARCHAR2) is select
bytes
from USER_segments
where segment_name = s_tab and --owner = s_own and
segment_type = 'TABLE';
cursor col_cursor (c_own VARCHAR2, c_tab VARCHAR2) is select
owner,
upper(column_name),
upper(data_type),
data_length,
data_precision,
data_scale,
nullable,
default_length,
data_default,
column_id
from all_tab_columns
where table_name = c_tab and owner = c_own
order by column_id;
cursor pk_cursor (c_own VARCHAR2, c_tab VARCHAR2) is select
owner,
upper(constraint_name) constr_name,
DECODE(constraint_type,'C','CHECK','P','PRIMARY KEY','R','FOREIGN KEY',constraint_type) constr_type,
search_condition search_cond,
R_owner,
R_constraint_name
from all_constraints
order by constraint_name;
cursor pkcol_cursor (c_own VARCHAR2, c_tab VARCHAR2, c_pk varchar2) is select
column_name
from all_cons_COLUMNS
where table_name = c_tab and owner = c_own and constraint_name = c_pk
order by position;
cursor CU_pk_tabl_name (c_own VARCHAR2, c_PK VARCHAR2) is select
table_name
where constraint_name = c_pk and owner = c_own;
The script below can help you to create constraints as well.
Hope this helps.
set verify off
set feedback off
Prompt
Prompt CONSTRAINT statements for those in the database (except for the SYS user).
Promp
clear columns
Accept Table_name Prompt 'Enter Table name to reverse engineer constraints for: '
Accept owner Prompt 'Enter owmer of Tables to reverse engineer constraints for: '
Accept constraint_type Prompt 'Enter type of constraint to create for (P,U,R,C,%): '
set termout oFF
Spool RE.Con
declare
upper(t.owner),
upper(t.table_name),
t.pct_free,
t.pct_used,
t.ini_trans,
t.max_trans,
t.tablespace_name,
t.initial_extent,
t.next_extent,
t.min_extents,
t.max_extents,
t.freelists,
t.freelist_groups,
t.pct_increase,
upper(c.constraint_name) constr_name,
DECODE(constraint_type,'C','CHECK','P','PRIMARY KEY','R','FOREIGN KEY','U','UNIQUE',constraint_type) constr_type,
c.search_condition search_cond,
c.R_owner,
c.R_constraint_name
from all_tables t,all_constraints c
where t.owner != 'SYS'
AND t.owner LIKE UPPER('&&owner')
AND t.table_name LIKE UPPER('&&Table_name')
AND t.table_name = c.table_name
AND t.owner = c.owner
AND c.constraint_type LIKE UPPER('&&constraint_type')
order by DECODE(constraint_type,'P',1,'U',2,'R',3,'C',4,5),t.owner, t.table_name;
bytes
from USER_segments
is select
owner,
R_owner,
R_constraint_name
order by DECODE(constraint_type,'P',1,'U',2,'R',3,'C',4,5);
column_name
order by position;
table_name
CURSOR CU_ind (c_own VARCHAR2, c_tab VARCHAR2,c_ind VARCHAR2)
IS
SELECT owner,
index_name,
uniqueness,
tablespace_name,
ini_trans,
max_trans,
pct_free,
pct_increase,
initial_extent,
next_extent
FROM all_indexes
WHERE owner = c_own
AND table_name LIKE c_tab
AND index_name LIKE c_ind
ORDER BY 1,2
R_ind CU_ind%ROWTYPE;
function wri(x_lin in varchar2, x_str in varchar2,
x_force in number) return varchar2 is
L_force NUMBER;
if length(x_lin) + length(x_str) > 80
then
lv_lineno := lv_lineno + 1;
-- insert into tabl_temp values (lv_lineno, x_lin);
DBMS_OUTPUT.PUT_LINE(x_lin);
if x_force = 0
then
return x_str;
else
-- insert into tabl_temp values (lv_lineno, x_str);
DBMS_OUTPUT.PUT_LINE(x_str);
return '';
end if;
else
if x_force = 0
then
return x_lin||x_str;
else
-- lv_lineno, x_lin||x_str);
DBMS_OUTPUT.PUT_LINE(x_lin||x_str);
return '';
end if;
end if;
end wri;
PROCEDURE PR_get_constr_col (lv_owner VARCHAR2, lv_table_name VARCHAR2, lv_constr_name VARCHAR2,lv_constr_type VARCHAR2)
IS
L_comma CHAR(1) DEFAULT '';
a_lin := wri(a_lin,' '||RPAD(' ',LENGTH(lv_constr_type)+1)||'(',1);
open PKcol_cursor(lv_owner, lv_table_name, lv_constr_name);
loop
fetch pkcol_cursor into
lv_column_name;
exit when pkcol_cursor%notfound;
a_lin := wri(a_lin,' '||RPAD(' ',LENGTH(lv_constr_type)+1)||L_comma||lv_column_name,1);
L_comma := ',';
end loop;
close pkcol_cursor;
a_lin := wri(a_lin,' '||RPAD(' ',LENGTH(lv_constr_type)+1)||')',1);
END PR_get_constr_col;
a_lin := '';
open tab_cursor;
loop
fetch tab_cursor into
lv_owner,
lv_table_name,
lv_pct_free,
lv_pct_used,
lv_ini_trans,
lv_max_trans,
lv_tablespace_name,
lv_initial_extent,
lv_next_extent,
lv_min_extents,
lv_max_extents,
lv_freelists,
lv_freelist_groups,
lv_pct_increase,
lv_constr_name,
lv_constr_type,
lv_search_cond,
lv_R_owner,
lv_R_constr_name;
exit when tab_cursor%notfound;
-- Ignore system constraints for NOT NULL
IF lv_constr_type='CHECK'
AND lv_constr_name like 'SYS%'
AND lv_search_cond like '%IS NOT NULL'
THEN
NULL;
ELSE
IF L_add_owner = 'Y' THEN
a_lin := wri(a_lin,'ALTER TABLE '||lv_owner||'.'||lv_table_name||' ADD (',1);
ELSE
a_lin := wri(a_lin,'ALTER TABLE '||lv_table_name||' ADD (',1);
END IF;
and lv_search_cond is NOT NULl THEN
IF lv_constr_name LIKE 'SYS%' THEN
a_lin := wri(a_lin,' CHECK',1);
a_lin := wri(a_lin,'-- original system constraint name was '||lv_constr_name,1);
ELSE
a_lin := wri(a_lin,' CONSTRAINT '||lv_constr_name,1);
a_lin := wri(a_lin,' '||lv_constr_type,1);
END IF;
a_lin := wri(a_lin,' (',1);
-- Cannot output lines longer than 80? chars so loop
lv_sc := SUBSTR(lv_search_cond,1,80);
WHILE LENGTH(lv_sc)>0
LOOP
L_space := INSTR(lv_sC,' ',-1);
IF L_space != 0 THEN
lv_sc := SUBSTR(lv_sc,1,L_space);
END IF;
IF LENGTH(RTRIM(lv_sc))>0 THEN
a_lin := wri(a_lin,' '||RTRIM(lv_sc),1);
END IF;
lv_search_cond := SUBSTR(lv_search_cond,LENGTH(lv_sc)+1);
END LOOP;
a_lin := wri(a_lin,' )',1);
ELSE
-- Get constraint columns
PR_get_constr_col(lv_owner, lv_table_name, lv_constr_name,lv_constr_type);
END IF;
-- Get index details for PK or UK
IF lv_constr_type='PRIMARY KEY'
OR lv_constr_type='UNIQUE' THEN
OPEN CU_ind (lv_owner,lv_table_name,lv_constr_name);
FETCH CU_ind INTO R_ind;
CLOSE CU_ind;
a_lin := wri(a_lin,' USING INDEX',1);
a_lin := wri(a_lin,' PCTFREE '||R_ind.pct_free,1);
a_lin := wri(a_lin,' INITRANS '||R_ind.INI_TRANS,1);
a_lin := wri(a_lin,' MAXTRANS '||R_ind.max_trans,1);
IF L_storage = 'Y' THEN
a_lin := wri(a_lin,' TABLESPACE '||R_ind.tablespace_name,1);
END IF;
END IF;
-- Get other end of FK (reference tablename and columns)
IF lv_constr_type='FOREIGN KEY' THEN
-- a_lin := wri(a_lin,' '||RPAD(' ',LENGTH(lv_constr_type)+1)||')',1);
OPEN CU_pk_tabl_name (lv_r_owner,lv_r_constr_name);
FETCH CU_pk_tabl_name INTO lv_r_tabl_name;
a_lin := wri(a_lin,' REFERENCES '||lv_r_owner||'.'||lv_r_tabl_name,1);
ELSE
a_lin := wri(a_lin,' REFERENCES '||lv_r_tabl_name,1);
END IF;
-- a_lin := wri(a_lin,' '||RPAD(' ',LENGTH(lv_constr_type)+1)||'(',1);
CLOSE CU_pk_tabl_name;
PR_get_constr_col(lv_owner, lv_R_tabl_name, lv_r_constr_name,lv_constr_type);
END IF;
-- Get index/storage stuff here
a_lin := wri(a_lin,')',1);
a_lin := wri(a_lin,'/',1);
-- a_lin := wri(a_lin,'--',1);
END IF;
end loop;
close tab_cursor;
exception
when others then
rollback;
raise_application_error(-20000,
'Unexpected error on ' || lv_table_name ||
', ' || lv_column_name || ': ' ||
to_char(SQLCODE) || ' - Aborting...scl='||LENGTH(lv_search_cond));
end;
Spool Off
undef table_name
undef owner
set verify on
set feedback on
set pagesize 30 head on lines 100
set serveroutput off
Prompt
Prompt You now have a script called RE.Con to use as required
Prompt
