ASP and Oracle 'date format' problems
Results 1 to 7 of 7
Thread: ASP and Oracle 'date format' problems
    Unhappy
    Hi!
    I'm managing my Oracle 8.0.5 by using ASP.
    I've got a problem with date format, because in Oracle
    it's DD-MMM-YYYY (23-DEC-1999), but in ASP it's
    DD-MM-YY (23-12-99). So I get problems like 'not valid
    month' when trying to modify a date via ASP.
    I encourage users to change it manually, but it's
    very hard for them.
    I tried (on Oracle) with:
    ALTER SESSION SET NLS_DATE_FORMAT = 'DD/MM/YY'
    but it does not work.
    I tried (on ASP when loggin) with:
    querydate = "ALTER SESSION SET NLS_DATE_FORMAT = 'DD/MM/YY'"
    set rsdate = connection.execute (querydate)
    but It does not work.
    Any suggestion?
    LARRY ELLISON
    Saskatoon, SK, Canada
    Why not use the query with 'DD/MM/YY' in the formating method. By the way, you would want to look into changing the ASP date format, as that approach of DD/MM/YY is not advisible, as we all know the cause of Y2K problem.
    So be aware of this type of formating.
    Unhappy
    I do not understand when you say <>.
    LARRY ELLISON
    I do not understand when you say: "use the query with 'DD/MM/YY' in the formating method"
    When you pass the query to the database send it to get it formated as you want.
    example:
    select sysdate from dual;
    Formated way is;
    SQL> select sysdate from dual;
    SYSDATE
    20-JUL-01
    SQL> select to_char(sysdate,'DD/MM/YYYY') "My Date" from dual;
    My Date
    20/07/2001
    SQL> select to_char(sysdate,'DD/MM/YY') "Your Date" from dual;
    Your Dat
    20/07/01
    Hope this would explain you.
    [Edited by sambavan on 07-20-2001 at 12:13 PM]
    LARRY ELLISON
    Sorry about the previous post, I ended up choosing the edit, instead of quote option. My moderator privileges had not warned me of this, as a result had allowed me to post as ellison.
    My deepest appologies to this forum members on this mistake.
    Sam :(
    Typical DBA mistake: grant too powerfull privileges to a user and see what you get.....
    Yep...
    Too much of privileges, too much of resposiblilites ...
    Once is way good enough
