Form: Using trigger to filter the data
Thread: Form: Using trigger to filter the data
    May 2001
    Unhappy
    Hi! Could you please help me please? I am trying to use 'when button pressed-trigger' to filter the data.
    The purpose is :if someone press the button then it will execute only the data that has got the same depot_id and periode.
    Is there any mistake on this trigger?
    set_block_property('m_form1',default_where,'depot_id ='''||:m_form1.depot_id||' and '||
    'periode>='''||:m_form1.f_periode1 ||' and '||
    'periode<='''||:m_form1.f_periode2 );
    Set_Record_Property(:system.cursor_record, 'm_form1', STATUS, QUERY_STATUS);
    execute_query;
    set_block_property('m_form1',default_where,'');
    Thank's in advance!
    I think you're missing some single quotes:
    set_block_property('m_form1',default_where,'depot_id ='''||:m_form1.depot_id||''' and '||
    'periode>='''||:m_form1.f_periode1 ||''' and '||
    'periode<='''||:m_form1.f_periode2||'''');
    execute_query;
    I'm not sure why you're using set_record_property. What's the point? You could replace that line with go_block('m_form1') then do your execute_query as before. I hope 'm_form1' is the name of a data block. If not, none of this code will work.
    Oracle DBA and Developer
    May 2001
    Thanks to kmesser!
    It does works!
    Thank's a lot kmesser for the help !
    Antony
