HI All,
I have to design a procedure which has to run a shell script aftre completing some activity.Is it possible to create such a procedure?
Thanks in Advance
I dont know and I dont think so :(
If you know how to execute shell script from C++ function, you will be able to execute it from Oracle function.
I think you have to write C++ external function which makes it for you.
Little sample:
if you create file tmp.c
main()
int status;
if (fork() == 0)
execl("/bin/date","date",0);
wait(&status);
then compile it: make tmp
oracle@mci:~/temp > ./tmp
Thu Jun 21 12:25:44 BST 2001
You will get date time. Approximatly the same you may do in your case just call 'sh script_name'.
Best wishes!
I dont think you can execute the Shell from the C or C++ executible. If you want to do this seach for the this
"Calling External Procedure".
Good Luck
Chan
OCP7.3/8.0/8i/9i
Sun Certified Sys. Admin
you can definately run programmes written in java c and c++ in oracle 8i.but you cant run a say korn shell script.could you tell me your exact requirements.you can also refer oracle pl/sql adavnced programming for this.but i dont think so executing a shell script is possible.
hrishy
Use java. We do this to call external shell scripts from within a package.
follow the JDBC examples found in the docs.
Create a java stored procedure with similar patterns as the sql strored proc.
this is how I did it... BTW, you need the JVM installed ($ORACLE_HOME/javavm/install/initjvm.sql) have 50M of shared_pool at least when youinstall it (as sys). Again, read the docs on this.
HAve your own procedure call the java proc: example:
create or replace package body java_integration as
procedure integrate (business_id in varchar2, file_name in varchar2) is
language java name
'java_integration.integrate(java.lang.String, java.lang.String)';
end java_integration;
You can do with a proc, and not a pkg, but I prefer packages.
In my other code, simple SQL I call this one:
java_integration.integrate(V_business_id, V_file_name);
This call the above java proc, which then calls the java_integration program, of the same name..
in the code I have something like this: I pass in the arguments and the path of the executable (which I hard code in my case), and execute it.
java_integration.java:
public class java_integration
public static void main (String args [])
public static void integrate (String biz_id, String file_name)
try {
int exitValue;
Process proc;
String exec_stmt = "/integrate_external/RTNYC/integrate.sh";
exec_stmt += " " + biz_id + " " + file_name;
System.out.println(exec_stmt);
proc = Runtime.getRuntime().exec(exec_stmt);
proc.waitFor();
exitValue = proc.exitValue();
System.out.println("Exit condition: "+exitValue);
catch (Exception e)
System.out.println("failure in callnow");
System.out.println(e.getMessage());
This and the other procedure must be loaded and compiled:
loadjava -u DB_USER/DB_PASS@CONN_STR -resolve java_integration.class
then sqlplus USER/PWD
@java_integration.sql (contains the package above)
that's mostly it. good luck.
THERE IS NOTHING IMPOSIBLE !!!
O'k !
Little lesson for those guys who don't know C++ & Unix & Shell together:
step 1:
create file called : hello.sh
hello.sh:
mkdir /home/oracle/temp/hello
step 2:
create C++ programm: temp.c
temp.c:
#include
main()
if (fork() == 0)
execl("/bin/sh","/home/oracle/temp/hello.sh","hello.sh", NULL);
step 4:
make temp
step 5:
./temp
step 6:
check new directory. :-)
QUESTION IS HOW TO CAN I DO IT ?
Best wishes!
Good Luck
[Edited by kgb on 09-07-2001 at 10:30 AM]
