    Jun 2001
    Hi all,
    I am trying to set the "default where " clause dynamically using set_block_property builtin .My code likes this....
    set_block_property(blk_id, default_where,'VW_CASEADDRESS_CASEMAIN.CSM_CASENO'||' '||'like'||' '||'(:CTRBLK.CASE_NUMBER%)');
    The Error says "Unable to fetch records" and its not identifying "%"........it says invalid character.
    Can anybody please solve it.
    saritha
    Try to separate "%" out of the ":CTRBLK.CASE_NUMBER%" and use "||" to concatenate the "%".
    HTH
    Jun 2001
    HTH
    I tried different ways to do that it doesn't show be error but it doesn't do what asked to do....
    whereclause varchar2(80):='VW_CASEADDRESS_CASEMAIN.CSM_CASENO'||' '||'like'||' '||''':CTRBLK.CASE_NUMBER''''%''';
    This is what I tried but it didn't work .....
    how should I didplay normal where cluase
    Sep 2000
    To display WHERE CLAUSE at any point of time, use:
    MESSAGE('Default Where Is : '||GET_BLOCK_PROPERTY(default_where, block_name) ) ;
    When you are dynamically setting the WHERE Clause for a block, you dont need to the block name (i.e. just use Field_Name and no need to use Block_Name.Field_Name)
    Try to concatenate % as HTH suggested.
    Hope this will help.
    Pinakin
    get_block_property(BLOCK_NAME, default_where);
    you DO need the block name if you are concatenating a value from an item in another block:
    set_block_property('PEOPLE',default_where,'name like ''%'||:control_block.text_item6||'%''');
    go_block('PEOPLE');
    execute_query;
    This code DOES WORK - I JUST TRIED IT.
    Oracle DBA and Developer
