Results 1 to 10 of 14
    Red face
    pls. helpme
    oracle is giving the error saying that oracle is not avialable.
    yester day it is working fine.today it is giving error.
    Ireland/Dublin
    Check Unix environment if you have wrong ORACLE_SID parameter you get this error. Fro example instance name is 'demo' and ORACLE_SID='' you get the error.
    ORACLE_SID must be = 'demo'
    Best wishes!
    Originally posted by ravisanapala
    pls. helpme
    Jun 2001
    Let me know your OS, Oracle Version. And how u r connecting to Oracle (thru SVRMGR or SQL*PLUS) , what error u got.
    Jun 2001
    IN NT, if you open regedit.exe
    You can find the ORACLE_SID in the item of home0
    chineseboy
    Originally posted by vutukuri
    we are using nt4.0 with service pack 5,oracle8.1.5
    in services it is showing as serivce started.once if we connect from sqlplus then it is giving the error
    Germany
    Check the status of the listener.
    > lsnrctl status;
    If your listener is not started,
    >lsnrctl start;
    If you are working on the host, then the listener should not matter because of the bequeath connection.
    Good luck.
    David Knight
    OCP DBA 8i, 9i, 10g
    Ireland/Dublin
    How many instances do you have? If > 1 then check current Oracle's home. And send Oracles' error message to forum.
    If your listerner is worlking fine, then start up server manager, connect as internal or any sysdba and issue command:
    startup open
    Nizar
    Jul 2000
    Hey have you started with startup mount pfile='path' ?
    OCP 8.0, 8i, 9i
    Mar 2000
    CA
    Startup Oracle manually from SVRMGRL.
    Kishore Kumar
