this is problem about data block at real oracle 8i ocp exam.
i don't sure the right answer, please explain
Which two prameter might affect the concurrency of transactions on a data block? (choose two)
A.PCTUSED
B.PCTFREE
C.INITRANS
D.MAX_EXTENTS
E.NEXT_EXTENTS
i choose : B,C
i put the problem at ocp furmus, but no one answer, hope have answer at here.
Your answer is exactly correct. The lock contention is depends on INITRANS & PCTFREE .
The first is no of transactions can update that datablock simultaneously is depends on INITRANS.
The second one is if u set INITRANS to more than 1, it allows two TX's can update on that datablock. then the contention is switched to the available space, to update the row(s). If u have not enough space to update the row(s), it causes the TX to wait. The space available for update is defined by PCTFREE.
Other parameters are not related.
