    Jun 2001
    Arrow
    I need to find a way to automatically make a script run against a certain instance on my dB. Is it possible? Is it possible to run scripts from the command line? SVRMGR? SQL Worksheet? SQLPlus?
    Any ideas are welcome!
    Germany
    Which platform?
    David Knight
    OCP DBA 8i, 9i, 10g
    Portsmouth, NH, USA
    Wink
    On Unix platform you can run a cron-job to automate a script.
    On NT you can use TASK scheduler to run a script if you like.
    - Magnus
    Jun 2001
    Platform
    Windows NT 4.0 SP6
    Oracle 8.0.5
    Also, I use the scheduler service all the time, but to execute an oracle script? I thought you had to be in SQL Worksheet or SQLPlus, etc. to do that?
    Dallas:TX:USA
    you can schedule to run a batch file under WinAT or AT program on Windows NT. The contents of the batchfile will be like --
    C:\ORACLE\ORA81\BIN\SQLPLUSW.EXE userid/pass@hoststring @c:\scripts\Myscript.sql
    Also you can go to http://www.americansys.com/ and download a free version of EZSchedular for NT. It's pretty neat !!!
    - Rajeev
    Rajeev Suri
