How to run a sql script using the dbms_job package?
VARIABLE jno number;
DBMS_JOB.SUBMIT (
:jno,
'my_job;',
SYSDATE ,
sysdate + 1/24'
COMMIT;
no, this run a stored procedure in the database
I WANT TO RUN A SCRIPT.
EX:
C:\THIS_IS_MY_SCRIPT.SQL
You can't unless you call some external or database-stored java function that in turn will run your OS script.
But given it another though, why would you then use DMS_JOB at all? why not simply use OS scheduler (cron, at, ....)? DBMS_JOB is ment to use with stored procedures. OS scheduler is ment to use with OS scripts....
[Edited by jmodic on 05-30-2001 at 05:27 PM]
i dont want to use **** from nt or unix, i want to use oracle stuff.
Yeah, well then you'll have to rewrite your SQL*Plus scripts into stored procedures....
lol
i dont want to use **** from unix or NT ..............i was wunderin waht makes you say so..............always try to make things simple..................dont add complexity unnecssarily..........
hrishy
ok, then how can i run a script from a procedure?
