pupbld.sql
Thread: pupbld.sql
    In 8.1.7 is pupbld.sql loacted at ORACLE_HOME/dbs/? I just created a DB manually and I'm trying to run that script as system but anytime I try it does not work.
    e.g.
    SQL> @$ORACLE_HOME/dbs/pupbld.sql
    SP2-0310: unable to open file "/u01/app/oracle/product/8.1.7/dbs/pupbld.sql"
    SQL>
    When I try to connect as an ordinary user, I get the message so I need to run that script:
    SQL> connect michael_pak
    Enter password:
    Error accessing PRODUCT_USER_PROFILE
    Warning: Product user profile information not loaded!
    You may need to run PUPBLD.SQL as SYSTEM
    This file is available at two locations
    1) ORACLE_HOME/ora81/sqlplus/admin
    2) ORACLE_HOME/dev/DBS
    Santosh
    I could not find it.
    $ cd $ORACLE_HOME/dev
    ksh: /oradata/ora/oracle/product/8.1.7/dev: not found.
    $ cd $ORACLE_HOME/ora81
    ksh: /u01/app/oracle/product/8.1.7/ora81: not found.
    I am using UNIX
    greenwich.ct.us
    It should be in $ORACLE_HOME/sqlplus/admin on unix. If not, from an OS prompt:
    cd $ORACLE_HOME
    find . -name pupbld.sql -print
    to find out where it is
    marist89@yahoo.com
    http://marist89.blogspot.com/
    Get Firefox!
    I got it. Thanks
