Thread: ORA-12154: Could not resolve service name
    May 2001
    Brazil
    I'm with this problem on one station that is running my application. This application was developer with Visual Basic 6.0 and I have on this machine two Oracle Clients (one for 7.3 and another for 8.1.6)
    I wait for help.
    Ps: Sorry my poor english..
    Ivan Margraf Jr.
    Ponta Grossa - Brazil
    Saskatoon, SK, Canada
    Set your ORACLE_HOME to 8.1.6 client
    then set other environment parameters. Then make sure that you have the entry for the server on your tnsnames.ora, could be found under ORACLE_HOME/network/admin/ Once you confirm that you can connect to the server as
    username/passwq@servicename
    or set your service name under TWO_TASk and then you can just enter user name and password.
    May 2001
    Brazil
    I already set my oracle_sid to Client 8.1.6 and configure my tnsname.ora to access my database, but i didn't have result. Do you thing that the problem is on application or some Visual Basic component?
    Jul 2000
    you will find multiple tnsnames.ora files on this client machine.
    Update all of them properly. In the process, you can find out which one it is exactly looking at.
    svk
    May 2001
    Brazil
    Thanks, it's solve my problem....
